Autometer Gauge Install?
Discussion in 'ECU's, Electronics, and Tuning' started by importimage, May 19, 2003.
  1. importimage
    importimage Senior Member
    British Columbia, Canada
    I have hooked up 3 autometer gauges (Pyrometer, Oil Temp, and Oil Pressure) except for the positive wires. I have a lot of 5 positive wires to hook up. Where do you recommend running all of these wires to??
  2. sirkurtius
    sirkurtius Member
    toronto canada
    if its just the positive wires and not the signal wires then i suggest to just hook them up to the positive battary termal.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Except then the back lights would always be on. You want to tap a wire that is switched, either when you turn the car on or when you turn the lights on.
  4. sirkurtius
    sirkurtius Member
    toronto canada
    if u want a switch that will turn on then try your ashtray light, or just wire them to your combo-switch on your steering colomn
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    get a test light and go to the fuse box... there are 5 spade connectors coming off of it.. and there is one or two that are switched w/ the key
