autometer tach
Discussion in 'Car Audio / Security / Electronic Accessories' started by 1993hondadelsol, Jan 11, 2010.
  1. 1993hondadelsol
    1993hondadelsol New Member
    ok i hook a tach up in my del sol everything works but the meter it doesnt move i connected it directly to the neg of coil but i noticed that the spring is missing out of the coil would that effect it not moving????
  2. 94civicturbo
    94civicturbo New Member
    Liberty, IN
    good job starting your own thread! (everyone cheer) sorry lol
    make sure its hooked up right again and make sure you have a good connection on everything
  3. 1993hondadelsol
    does the ground need to go to the battery? i have it grounded to the lighter
  4. 94civicturbo
    Liberty, IN
    no it doesnt have to, just make sure its grounded well, preferably directly to metal
  5. justastockef
    justastockef New Member
    jax, fl
    the negative of the coil? why? the tach test connector is around the driver side fender/firewall area. it is a 2 pin connector. thwat is where you want to connect the tach wire at, not the negative of the coil.
  6. 94civicturbo
    Liberty, IN
    mines connected on the negative of the coil and it works lol
  7. 1993hondadelsol
    and not to the ground on the lighter and i used speaker wire lol i am ghetto should i change that
  8. 90si2
    90si2 New Member
    use legit wire and do it right the first time. why do things twice
  9. 94civicturbo
    Liberty, IN
    yeah use regular wire lol
  10. INJEN78
    INJEN78 HS LEGEND
    OHIO
    black to a solid metal ground.green goes to the tach wire from the dizzy,white goes to lights and red goes to a switched power source..
