Automotive Formulas
Discussion in 'Reference Materials' started by pissedoffsol, Mar 1, 2004.
  1. pissedoffsol
    Found a cool site with a bunch of equations for solving for "stuff" :)
    orig posted on http://www.westernracing.com/reference/formulas.htm
    Automotive Formulas
    Formulas for displacement, bore and stroke:
    cylinder volume = pi/4 x bore^2 x stroke
    stroke = displacement / (pi/4 x bore^2 x number of cylinders)
    Formulas for compression ratio:
    (CylVolume + ChamberVolume) / ChamberVolume
    chamber volume = cylinder volume / compression ratio - 1.0
    displacement ratio = cylinder volume / chamber volume
    amount to mill = (new disp. ratio - old disp. ratio / new disp. ratio x old disp. ratio) x stroke
    Formulas for piston speed:
    piston speed in fpm = stroke in inches x rpm / 6
    rpm = piston speed in fpm x 6 / stroke in inches
    Formulas for brake horsepower:
    horsepower = rpm x torque / 5252
    torque = 5252 x horsepower / rpm
    brake specific fuel consumption = fuel pounds per hour / brake horsepower
    bhp loss = elevation in feet / 1000 x 0.03 x bhp at sea level
    Formulas for indicated horsepower & torque:
    horsepower = mep x displcement x rpm / 792,00
    torque = mep x displacement / 150.8
    mep = hp x 792,000 / displacement x rpm
    mechanical efficiency = brake output / indocated output x 100
    friction output = indicated output - brake output
    taxable horsepower = bore2 x cylinders / 2.5
    Formulas for air capacity & volumetric efficiency:
    theoretical cfm = rpm x displacement / 3456
    volumetric efficiency = acutal cfm / theoretical cfm x 100
    street carb cfm = rpm x displacement / 3456 x 0.85
    racin carb cfm = rpm x displacement / 3456 x 1.1
    Formulas for tire size & their effect:
    effective ratio = (old tire diameter / new tire diameter) x original ratio
    actual mph = (new tire diameter / old tire diameter) x actual mph
    Formulas for g force & weight transfer:
    drive wheel torque = flywheel torque x first gear x final drive x 0.85
    wheel thrust = drive wheel torque / rolling radius
    g = wheel thrust / weight
    weight transfer = weight x cg height / wheelbase x g
    lateral acceleration = 1.227 x raduis / time^2
    lateral weight transfer = weight x cg height / wheel track x g
    centrufugal force = weight x g
    Formulas for shift points:
    rpm after shift = ratio shift into / ratio shift from x rpm before shift
    drivehsaft torque = flywheel torque x transmission ratio
    Formula for instrument error:
    actual mph = 3600 / seconds per mile
    speedo error percent = difference between actual and indicated speed / actual speed x 100
    indicated distance = odometer reading at finish - odometer reading at start
    odo error percent = difference between actual and indicated distances / actual distance x 100
    Formulas for MPH RPM gears & tires:
    mph = (rpm x tire diameter) / (gear ratio x 336)
    rpm = (mph x gear ratio x 336) / tire daimeter
    gear ratio = (rpm x tire diameter) / (mph x 336)
    tire diameter = (mph x gear ratio x 336) / rpm
    Formulas for weight distribution:
    percent of weight on wheels = weight on wheels / overweight x 100
    increased weight on wheels = [ distance of cg from wheels / wheelbase x weight ] + weight
    Formulas for center of gravity:
    cj location behind front wheels = rear wheel weights / overall weight x wheelbase
    cg location off-center to heavy side = track / 2 - [ weight on light side / overall weight ] x track
    cg height = [ level wheelbase x raised wheelbase x added weight on scale / distance raised ] x overall weight
