Average power
UDT
What makes average power? How would you build to strive for the goal of high average HP numbers? Or is it more in the tuning?
you mean like with a flat torque band? if its about a flat torque band; which gives you balance between the whole rpm band, then yes tuning. also high compression and cams designed for mid-rpm power increase will work.
[post=419586]Quoted post[/post]​
Put down the crack. :p
