INJEN78
HS LEGEND
is there a differance between axles from an automatic and standard???i had an auto integra with blowntranny and want to put the motor in a crx..but the only thing left id need is axles...
also the rear suspension will bolt up in a crx right???i want to do a rear disk brake conversion and want to kno if i should just unbolt the whole assembly(control arms)or just the hub assembly
