axle help
Discussion in 'HYBRID -> ED-EF / DA' started by josh_crewdson@y, Aug 17, 2010.
  1. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    will 92-00 civic d series axles fit in a 90 civic?
    I think they'd be too long, but I'm sure someone's dealt with this before.
    couldn't find any info...
  2. invisibledemon
    Tn
    no, i dont believe they will fit.
    you'll need to get the ones for your year.
  3. josh_crewdson@y
    nova
    they slide into the 90 dx tranny and hubs.. i put them beside each other and they're the same length.. impossible? i thought the ef's weren't as wide as the ek's, body wise?
  4. invisibledemon
    Tn
    call a parts place and get the part numbers for each year.
    if they match, then they're the same.
    if they dont match, then they arent the same.
    sometimes, you cant see the difference in length by eye. 1/8th of an inch can be the deciding factor of whether or not they fit. and you wouldnt be able to tell that little bit of difference by eye.
  5. SLAZER
    SLAZER VTEC obsessed
    NEW YORK
    what axles would you use in a 90 civic dx hatch with a d16z6 swap?? i've searched the site quite a bit and can't seem to find the answer.
  6. D16SiHatch
    D16SiHatch New Member
  7. B 16 CIVIC
    B 16 CIVIC New Member
    i need help wit my axel problem if some one could call or text me with help at 760 995 5983
  8. invisibledemon
    Tn
    make a new thread,
    include the details of your question.
    go from there. or, use the search function to see if your question has already been answered before.
