Axle help
Discussion in 'HYBRID -> ED-EF / DA' started by hondaman85, May 3, 2007.
  1. hondaman85
    hondaman85 Large Member
    C town
    Ok I swaped a b16a into my crx It came with everything but the axle they gave me does not fit on the right side some one told me to try 88 integra one should I?:confused:
  2. skank2
    skank2 New Member
    DFW, texas
    it doesnt fit on the right side as in......? in the spindle or the tranny?
  3. hondaman85
    C town
    the axle is to long I cant get the spindle to line up to bolt the bottem castle nut up
  4. skrotm
    skrotm if you boost it..........
    moultrie, ga
    the axles you use depend on the half shaft you have. if you have an obd0 halfshaft you need to use obd0 integra axles. if you have an obd1 halfshaft, you need obd1 axles...... oh and an auto half shaft is a little bit longer than a manny one.
  5. hondaman85
    C town
    well I got the left side in fine and I guess its obd0 because it all came togather but when I put the right side in it was way off and it was really hard to pull out after putting in
