Axle leaking oil?
Discussion in 'General Tech and Maintenance' started by sureshot007, Sep 2, 2005.
  1. sureshot007
    sureshot007 Member
    Where my drivers side axle (half shaft) plugs into the transmission, there appears to be some oil leaking from it. Did I miss something when I installed it? It appears to be in all the way, especially since I had to line up the holes on the engine block to mount it with.
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    There is an axle seal in there, you may have damaged it if you weren't careful. Not too hard to fix, though.
  3. 9sech22civic
    9sech22civic Senior Member
    sounds like your axle seal is bad, they can go bad when you swap out axles. No biggie its a 7 dollar part.
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    easy and cheap to fix but a shitty job
