Axle nut stuck
dmmd3
The axle nut is stuck on my 95 integra. I have a electric impact and have tried applying heat but it wont budge. Any other suggestions?
liquid wrench, let it soak in... and a huge breaker bar (i use my jack handle over as a pipe). get some leverage
Make sure you are using a very rugged breaker bar, slip a 3 foot cheater bar over the end of it, and the nut will come right off.
probably a stupid question but did you remember to straighten out the dent that keeps it locked in place?
Thanks for the replies guys. I ended up soaking it in pb blaster before work and then when I came home I gave it one more try with the impact and it came off. Go figure
