axle nuts!!
Discussion in 'Civic and CRX - EF' started by SLOWdelawareEG, Apr 24, 2008.
  1. SLOWdelawareEG
    SLOWdelawareEG my cars go fast
    hilton head island, sc
    doing my swap last nite/today, and cant get either axle nut off. im using a 1/2" breaker with a 3 foot cheater on the end! the whole car is wobbling and moving and bouncing up aand down but they wont budge. thought about cutting them off with a grind wheel.:D any quick suggestions?
  2. nootrac22
    exeter pa
    did you pull the tab out on the nut?
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    check for the tab like he said,,and then set the car back on the ground to break it free
  4. Jared759
    Jared759 Well-Known Member VIP
    SC
    I used a chisle and cut mine.
    =D
    Also used a torch
  5. SLOWdelawareEG
    this isnt my first rodeo.;) thats not the issue
  6. nootrac22
    exeter pa
    Also if you have someone to help, you can apply presure with the breaker bar and have them hit it with a sledge hammer (kinda like an impact wrench). heating the nut could help also, but don't use propane, if you dont have access to oxy/acetelen(sp), use mapp gas. it's much hotter than propane.
  7. AHHVTEC
    Alabama
    oh and make sure the tire are back on it before you set it on the ground to break it free
  8. SLOWdelawareEG
    i have acetylene. give me a few mins to go try this. i think im going to utilize the torch along with the giant breaker bar impact method. thanks fellas. wish me luck
  9. ACME CRX
    ACME CRX New Member
    Yea I had that problem with my CRX. I broke off the screwdriver tip trying to push the tab out. I tried to load it with BP Blaster then force it over. Didnt work. I applied heat to it then let it cool back down. Put it back on the ground, used a 3ft cheater bar, and had the fattest friend I could find stand then jump on the bar. That worked for me. My next attempt was going to be an air chisle. They always work... but usually you have to replace something else too because you damage it.
  10. dacheat
    dacheat ..is grounded.
    strongbadia
    exactly. ps there's no way on the planet i coulda gotten these off my car by myself. talk about pissed. thank god for he-ain't-heavy-he's-my-mechanic.
  11. SLOWdelawareEG
    got em. it took acetylene and me standing my skinny ass on a 4ft bar and jumping up and down.
  12. SLOWdelawareEG
  13. BrokenRex
    BrokenRex New Member
    before i bought my composite impact (1000ft. lbs) i used to put the car on the ground, get my 1/2" breaker bar, and put my jack handle over it. that made the length like 6' or so. stood on the end, and it would mostly do the job. with my new impact however, i dont even unstake em if the owner or myself has a new one, i just blast em off. puts a smile on my face every time.
  14. 93AccordEX
    93AccordEX New Member
    Life can be HELL without a good impact gun :)
