Axle poping
Discussion in 'General Tech and Maintenance' started by 95preludetypes, Dec 24, 2003.
  1. 95preludetypes
    95preludetypes Member
    i have a prelude with a h22. my driver side axle is poping when i turn, i jacked my car up and the cv boot i cracked who hard is it to replace and where can i buy remanufactured axles thank you. and is it worth repalceing both at the same time.
  2. mwvnos
    mwvnos Senior Member
    SC
    it will take you a while to change it.....autozone has axles with a lifetime warrentee...search function is your freind...
  3. DYTRADER1628
    DYTRADER1628 Member
    i just did mine 2 months ago. it was very easy. i think the hub nut it should be 22mm or 23mm you can rent that from auto zone. And if you buy the axle from autozone bring the old one back and you get a core charge. :D . for some reason mine is still making nosie down there i think it just my control arm though. <_<
  4. Jeef
    Jeef NO MA'AM Moderator VIP
    I recentlybought autozone axles and they are already clickng again 3 months later. They suck but the lifetime gurantee is good if the boot isnt ripped. It is a 32mm socket btw. I woudl replace both if the other one is getting shot since you already have the tools out, car jacked up and the tranny drained.
  5. h22bubbleback
    h22bubbleback Senior Member
    North Jerzey
    it doesnt take that long to change at all...autozone blows..go to NAPA for good axles, they also take cores back
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    On civics, integras and CRX's it is, but on accords, I am pretty sure that it is a 34mm. The prelude is probally the same
  7. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    NAPA has by far the best axles I've experienced so far. As mentioned above, stay far away from Autozone axles.
    And no, it won't take you long at all, and yes, the Accords and Preludes use a 34mm (MIGHT be 32) socket. Make sure you have a quality (not Husky) breaker bar and lots of WD-40. Some anti-sieze compound will also help if you plan on changing the axle again in the future.
  8. tab
    tab Super Moderator
    Aberdeen, Washington State
    I think the first time I changed one it took me 1 1/2 hours. That was sitting in wet rocks, with basic hand tools. You could easily cut that time in half, or even less. NAPA axle is still holding, and I beat the fuck out of them.
  9. 95preludetypes
    what kind of tranny fluid should i use
  10. Jeef
    Honda mtf if its a 5spd
