Ok I searched before I posted this but with my swap I am using the halfshaft from a delsol along with the axles. The trans im using is a J1 and now the seal on the driver side is leaking on the trans. I found out that this halfshaft is smaller diameter than the DA halfshaft but my question is do I need to switch back to a DA halfshaft and axle or what seal do I need to get?
I also found this info as well I check the parts out and what I found out is that the seal thats in the tranny is Shaft Size=1.811" Housing Bore=2.697" Outer Diameter=2.705" Width=0.295" and the seal for a 94 up integra is Shaft Size=1.575" Housing Bore=2.205" Outer Diameter=2.213" Width=0.354" so the 94 up is smaller
Thanks in advance
Thanks in advance
