Axle seal
Discussion in 'Prelude' started by MthaFuknGreen, Jan 18, 2009.
  1. MthaFuknGreen
    Lodi, CA
    i had a small fluid leak after i replaced the transmission coming from the left axle, i put the seal up as close as i could then used a few socket extensions and a hammer and pounded it a little bit, and for the most part it stopped the leak.
    but its still leaking a bit.
    is there something special im supposed to do?
  2. efhondakid
    Akron-Canton, Ohio
    If its still leaking then you damaged and/or didnt insall it correctly...
  3. eastbxc
    eastbxc Custom User Title
    Kansas
    You could of pressed it in to much....if I remember right I think your suppose to press the seal into so it sits flush???
  4. MthaFuknGreen
    Lodi, CA
    well, when i put the fluid in, i forgot about the seal.
    so it was still in the middle of the axle.
    so i got under the car real quick and pushed in in there.
    it didnt look damaged.
