Axle Snapping?
Discussion in 'General Tech and Maintenance' started by CARP 104, Nov 16, 2007.
  1. CARP 104
    CARP 104 New Member
    This civic I am looking into getting is putting down ~400HP to the front wheels. The guy selling it says it has Acura GSR axles (if I remember correctly). Im worried they might snap, has anyone else got experience with this?
    If your axle DOES snap what exactly happens thereafter....I have seen videos of cars axles snapping and their tires even falling off after this. I don't want that to happen on the highway....someone could get killed.
  2. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    honda axles are pretty stong. You shouldnt have a problem unless you launch at a high rpm with slicks.
    The car wont move after it breaks. THe only time you should worry about an axle breaking is when you have a welded diff otherwise dont worry about it. You should be ok.
    GL
  3. norcalgsr
    NorCal
    400WHP is enough to break a stock axle even with a stock transmission.. especially if he puts on a set of drag slicks. However, the tire will definitely not fall off if you break an axle, most likely it will just snap and you wont be able to move the car if it breaks while launching. However, if you have an LSD or a spool on the trans and it breaks while you're driving it hard (such as down a 1/4 mile at WOT) you could put it into the wall especially with a spool/welded diff. All the power will transfer to the one axle that isn't broken and push you right off the track.
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    as he said^^ it could snap..the wheel will not fall off..and the only problems you might encounter are the axle hitting/breaking something or the car losing control^^as he said again....if your that worried about axles snapping there is a site that sells axles in stages(ex. 1,2,3,4)
  5. CARP 104
    CARP 104 New Member
    Hmm. I don't know if this will help or not but right now it has a manual boost controller and is set for daily driving at ~12psi, and for racing he turns it to ~16-18psi. I wanted to switch to the Apexi boost controller that allows you to adjust the boost through each gear and reduce tire spin. Ex... 1st gear turbo maxes out at ~8psi, 2nd gear ~10psi, 3rd ~ 12psi, 4th~ 14psi, 5th~ 16psi or something like this (to keep from tire spinning in almost every gear).
    What kind of axles do most people putting down this type of power use? Could someone link me to some decent ones? Thanks guys
  6. Estorvito
    Orlando FL
    YOu should be allright with stock axle as long as you dont run 24" or bigger slicks. If you do, just feather the clutch on the launch and you should be ok.
    Id say your tranny will fuck up before the axle does. :)
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
  8. accord92lx
    accord92lx New Member
    sco-town
    put 800hp axels in your car thats wat i did..guranteed not to snap they are also like $800 but better to be safe then sorry
  9. Estorvito
    Orlando FL
  10. accord92lx
    sco-town
    lol first off i aint your son and second off why must you make a big deal out of something like being on the safe side with axels just cause i have 800+ hp axels just mean mine arent goin to snap so stfu and go bk to your mom and have her call you son.
  11. !!JdmDa9!!
    !!JdmDa9!! New Member
    FLORIDA
    My driver side axel is fucked thanks to motherducking nitrous
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok asshole...drag racing for years....you obviously dont know shit about anything and you obviously only drive the car...feather the clutch on a launch?!?!then how the fuck are you going to get a good launch if your feathering you dick munch....you will need stronger axles for the application
    and what car do you run low boost with 450+hp?!?!? i sure as hell no its not a honda with stock axles...SON!!!
  13. jspecbb2
    jspecbb2 New Member
    oh they will snap, but the car just stops moving until you put a new one in
  14. Estorvito
    Orlando FL
    My civic. :)
    Low boost 18psi.
    You drive a POS honda civic with a d series. SHUT THE FUCK UP. My helmet cost more than your whole setup. SON;)
    You guys suck. Fuckin' nOObs
  15. INJEN78
    INJEN78 HS LEGEND
    OHIO
    sry dude..my bro drives a civic with a d-series....
    i drive a crx with an UnKnOwN MOTOR...
    and im pretty sure your helmet didnt cost more than my setup...soo basically u can bang your ass...you think you can talk shit and act big
    "oh i drive a civic with low boost.its only at 18psi..i dont work on the car or know shit about it..and im on stock axles and when launching i feather the gas"
    suck a dick..and dont provide false info..FAGGOT
  16. Estorvito
    Orlando FL
    ohhh and look....Here you go nOObs.
    If you have the money, go get yourself gator or dss axles. Im just saying you dont really need it unless youre going to be at the track 24-7
    :p
    LDL speedshop In CA.
    Flamenco from texas
  17. Estorvito
    Orlando FL
    bahahahaha. wrong info?... I built my car by myself. KIddO'.
    Look at my build thread and then talk shit. I build FAST cars for a living... hahaha
    I make more money in a week than you and your brother will ever make in your entire life. lol God this is too funny.
    Try again^_^
  18. klyph
    klyph Dismember VIP
    North Pole, AK
    Estorvito will put a knife in you, son.
    :stfunoob:
  19. Estorvito
    Orlando FL
    yeah klyph.
    Fucking nOObs dont know shit...
  20. klyph
    klyph Dismember VIP
    North Pole, AK
    I like how he said you don't work on your car :roll:
    What a tool, kid can't even wear a hat correctly. Hey INJEN, keep your thuggin on the skreets, we don't need your bullshit in the tech forums.
