ok i got a 4g si hatch with a obd0 ls slated for install my question is what are the parts i need to build my own axles (tryin to save money). also i just finished a rear disc conversion and now my brakes rub when drivin downtown but not so much and the highway. the rubbing can get to the piont where if its not at full throttle the will nosedive to a halt. then after stopping with the car off for around five minutes the brakes back off and it drives and brakes fine. i have already replaced one caliper as a check to see if that corner stops rubbing with no luck. could it be because i didnt swap the proportioning valve, master cylinder or booster ( i would have but i found out after the swap that i needed them and by then the donor car was gone (damn this is long my bad) any help would be great thanks
