hey guys wondering if you can make a bseries intake manifold fit a d series head - i heard all you have to do it is drill alittle bit but want to know - i tried searching but came up empty - also will fuel rail and injectors fit and everything else work - thanks
No. You can move the injectors around if you stay within the same OBD revision, but the IM will not work. It's a different size... port spacing is most likely different.
