B-series and D-series parts
jdmspecdc5
Make offers. Will consider discounts with multiple purchases.
D-Series (parts off a d16a1)
D16a1 BARE DOHC head
D16a1 COMPLETE DOHC HEAD (cams, valvetrain, etc.)
D16a1 block (block, pistons, crank, oil pan)
D16a1 non-OBD distributor
D16a1 alternator
NGK wires
D16a1 oil pan
D16a1 intake manifold (PGM-FI)
D16a1 exhaust manifold
D16a1 stock exhaust
D16a1 air box w/ ducts
D16a1 tranny (no grinds)
D16a1 cams
throttle body
bare axles
intermediate shaft
Power steering bottle
Power steering pump
power steering bracket
power steering hoses
Power steering belt
COMPLETE POWER STEERING SYSTEM $40.00
A/C compressor
A/C compressor bracket
A/C refrigerant bottle
A/C condensor
A/C hoses
A/C compressor belt
A/C condensor fan
COMPLETE A/C SYSTEM(needs to be recharged) $60.00
COMPLETE cruise control unit and cable $50.00
B-series (parts off a b17a1)
b-series mounts (right mount, tranny mount, rear mount, front mount)
2 b-series axle CV joints w/ cut boots
b17 power steering pump
b17 a/c compressor bracket
b17 power steering bracket
power steering bracket and pulley
alternator ***pending***
alternator belt ***pending***
starter motor ***pending***
water pump ***pending***
i will post up with pictures and more things when i get home. make an offer on anything listed above.[/B]
I need the power steering rack....can you get that off the car & ship it to 31069?
If so, name a price...
ahedau: i'll see what i can do with the power steering rack. i'm considering going with a manual rack so i'll keep you updated.
cointelpro: the boots are cut. new ones would need to be used. i can check if the joint is ok. there is a whole bunch of greese still in there.
I need the throttle body with all sensors, etc intact. complete intake manifold with all sensors as well as fuel rail/injectors/fpr intact. I also need the distributor intact with all sensors, etc. thanks. please e-mail me at JCGator42@yahoo.com with a price for all of the above. I am assuming this came out of 88-91 CRX/Si? thanks.
JCC
yea you can get boot repair kits for like 10 bucks at autozone, but if the cv joints are already going out i dont want em, could you check for me, also you including intermediate shaft? how much shipped to 80020?
and im assuming b17a axels will fit a b18 :eek:
ahedau: i will be getting a manual steering rack this weekend so when i get the power steering rack out i'll let you know.
JCHatch: the parts came off of a 88 integra...very similar to the 89-91 crx.
cointelpro: it's just two cv joints that were in good condition. the boot was just torn and the axle shaft removed to keep transmission fluid inside the tranny when i bought the b17.
