b series and k series partout
kseries isboss
Hey everybody i've decided to start parting out alot of stuff I have laying around so i'll just start listing them.
b16a head- 3000 miles on the head- $1,400 all together
skunk2 stage 1 cams
supertech titanium valve springs and retainers
ferrera .5mm oversized valves
i will sell the cams and valve springs seperate but would prefer to sell the entire head as one.
ls block(s)
b18b1(2) $1250
the first one is brand new from the machine shop
83mm ctr pistons
stock ls rods
stock ls crankshaft
toda high velocity oil pump
arp rod bolts
gsr water pump
b18b1 $900
b16 p30 pistons
stock ls rods
stock crankshaft
gsr oil pump
gsr water pump
the second block's piston rings in no 1 cylinder went bad. 23% leakdown when I did the test. The other cylinder's passed with 14% no2, 16% no3, 15% no4. I personally would put new rings in all the cylinders but you could just do no 1 cylinder nd be fine.
Plus I've got a full new stock ls head minus the valve cover-$400
k24a4 head- 1200
brian crower stage 3 cams
supertech valve train
freshly machined with 400 miles on the setup
ummm o yea
i've got a hydrolocked k20z1
not selln the head but if neone wants the block it's yours for 100 bucks
haven't ripped the motor apart yet so idk how bad the block is but once i do i'll update the thread.
nd im goin home this weekend so ill add any parts i forgot
