B Series Axle Question
Discussion in 'HYBRID -> ED-EF / DA' started by HATCHET_HONDA, Feb 3, 2008.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    anybody know if the steering knuckles from the 90-93 integras will work for a b16 swap in an ef? i cant find any ex sedans but plenty of tegs
  2. efhondakid
    Akron-Canton, Ohio
    Im almost positive they will work, and while your at it do the rear trailing arms too.
  3. HATCHET_HONDA
    hobart, indiana
    then i will need to use the intermediate shaft too righ? cause it seems the abs axles are the only ones i see that have the female end to attatch the shaft
  4. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    The DX and LX knuckles are the same as the EX knuckles too. Pretty much all EF-ED knuckles will accept B series axles except for the knuckles from a CRX HF or the STD (4 speed) hatchback.
    You're gonna have to use the 90-93 integra intermidiate shaft no matter what knuckles you use and the 90-93 integra axles are the same weather they are ABS or not. The ABS ones just have the ABS ring on them...
  5. HATCHET_HONDA
    hobart, indiana
  6. HATCHET_HONDA
    hobart, indiana
    is there a 3rd axle then? cause on ebay they have the b16 swap axles but they have both male ends so thats why i was confused to how they would attatch to the int. shaft. i was thinkin it would go from the pass side to the trans then drivers side to int. shaft the an outer axle to the hub.
  7. B16RacerN2NR
    Moving back West...
    This is how it goes...
    Driver Side...
    hub:<axle>:IntermidiateShaft>:tranny:<axle>:hub
    :=female end < and > = male end
  8. HATCHET_HONDA
    hobart, indiana
    i get it now! the intem. shaft goes into the trans........ i feel dumb now lol i was thinkin the axle slid into the shaft on both ends. thanks for the lil illustration :)
  9. B16RacerN2NR
    Moving back West...
    :thumbsup:
  10. drummingpariah
    drummingpariah Author of the Madness Man
    Bay Area, CA
    That's actually a wonderful little diagram, but I can't even IMAGINE what kind of misconstrued sexual innuendoes someone else might see, assuming they weren't a part of the conversation already.
    ... that's just dirty.
  11. HATCHET_HONDA
    hobart, indiana
    WORD!!!!!
  12. 96prelude
    96prelude Senior Member
    Searcy Ar
    so any 90-93 teg axels will work?
  13. drummingpariah
    Bay Area, CA
    If you have ABS, get 90-93 ABS axles, if you don't have ABS, get 90-93 NON-ABS axles. That's the important part.
  14. BrokenRex
    BrokenRex New Member
    and because it's an EF, you dont have abs, so forgot all about abs, the non-abs items are cheaper anyhow.
  15. drummingpariah
    Bay Area, CA
    Yar. :thankyousigna2:
  16. JAKracing
    JAKracing New Member
    rocky mount, nc
    if u do buy DA knuckles, u need to get the calipers too. i have a std. hatch and that is what i had too do
  17. HATCHET_HONDA
    hobart, indiana
    plenty of teg knuckles in the boneyards round here..not sure the shape that the calipers are in..prolly have to pick up new ones
  18. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    w0rd. i swiped rear discs from a '90 teg but they were so rusty and the seals were in such bad shape I ended up getting remanufactured ones from the acura dealer and gave the junkyard ones as core deposit. they were $450 minus 2 $60 core fees. so i payed like $330...
    i'm stalking you around the forums man, lol. i hope your makin good progress, cant wait to see it!
  19. HATCHET_HONDA
    hobart, indiana
    lol.... well i just found a gsr head for the b16 hatch and im havin problems with the p28 ecu in the black hatch..its not reading codes...think i could swap in the p30 that i got for the b16 and see if the ecu is truly the prob? its kind runnin like crap..stallin and idlin funky sometimes
  20. YBLEGAL
    NW Indiana
    is the P28 running a D16 in the black hatch? i dont think a P30 will run a D well, it might tho still.
    o i saw you drivin like a week ago in hobart. revin up 1st gear. lol
