B Series Cam Guide
Discussion in 'Reference Materials' started by JDMilan, May 11, 2003.
  1. B16
    B16 Super Moderator VIP
    yay area, CA
    ITR and CTR exhaust cams are the same, i found my best results with those cams at +3deg intake and 0deg exhaust, guess every motor is different eh? how much of a diff were you expecting? what motor and cams were on before?
  2. citrus
    citrus Junior Member
    Didn't really know what to expect, just considered them as a cheap alternative to TODA's.
    I was running stock B16A intake and exhaust cams before. I think I tried 3°adv and 0°ret, but I will double check. Every motor is different though, true dat.
  3. kaeson
    kaeson Junior Member
    I have a pair of crower 401 (n/a) cams. When you speak of reliability what do you mean? How can a cam not be reliable? now correct me if im wrong...its a peice of steel (so to speak), with lobes on it that open and shut valves. How does this relate to reliablity. Please let me know b/c your making me reconsider putting them in my Integra. :angry:
  4. Metro
    Metro Junior Member
    Sandefjord, Norway
    Got any cam info like this for the B20Ax engines for the 3rd gen prelude?
  5. calvin
    calvin Senior Member
    NETHERLANDS
    I thought this might be handy:
    Integra GS-R/SIR II (b16a2/a3)
    Int-230 dur. / 10.6mm lift
    Exh-227 dur. / 9.4mm lift
    Integra XSi/SIR 1 (b16a1)
    Int-230 dur. / 9.7mm lift
    Exh-225 dur. / 8.9mm lift
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    hey phockers........
  7. allgo
    allgo Senior Member
    bump! are u going to post new cams spec on there? Rocket m22, buddy club, blox, ect...
  8. DravenVX
    DravenVX Member
    i got a question for ya JDMilan. I have a 99 JDM B16A and i have the Skunk2 chip in my P28 ECU. Now the rev limiter is now at 9000 so can i safely take the revs that high without modifying anything else? Do i need some valve springs? oh and I am also getting Skunk2 cam gears soon if that helps? I just don't wanna screw up my engine that's all! :)
  9. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    Dual Valve springs and titanium retainers are your best FRIEND. You should have started a new thread though and not posted here but hey I am not a Moderator so it's all good with me.
  10. becoming
    becoming Member
    Jasper, AL
    Well as far as you sohc'ers, i personally would not recomend the Zex cam to you. my friend had one and you could barely even tell it was there! I think his air intake had more effect on his motor than the cam did! But as far as the skunk2 cam for the sohc application, i have never know anyone to do it.
    But a question i do have for you JDMilan, is that i have a 98 LS bottom end, with a 95 GSR head{Crower dual spring, Ti retainers and keepers, Ferrea stainless valves}. I also have a Skunk2 IM and a crank girdle in the block to help rigidness at higher RPM's, but do not want to spin it highter than 8200 or so...and my dilema is that i have a turbo kit to either put on this motor, or my LS swap i'm putting in my del Sol, and keep my hatch all motor. But can't decide which set of cams to get if i do go all motor in my hatch, because i want to keep a narrower power band{3k to 8k}, but in doing that, i want to see "awesome" power out of a set of cams if i do go that route! What are your suggestions? I also have planned on ITB's for it if i do go all motor also. And FYI this is still a "street car", but with no emisions to worry about down here in Alabama :D . So i have no worries about that aspect of things, I just want Balls-to-the-wall power!
  11. JDMilan
    Boca Raton, FL
    In stock condition I would so nay, the stock cams make power until roughly 8-8200rpms. Anything past that wont do you any good. High revs doesn't mean more power unless your cams will produce it otherwise. I would personally set your rev limit at 8200, so that if your wheels do spin you won't put any stress on the motor. Good luck.
  12. becoming
    becoming Member
    Jasper, AL
    If that was directed towards me, I don't follow....lol
  13. ferrallas
    ferrallas Junior Member
    Then Integra GSR cams best than Civic Si 99, its a good upgrade?
  14. JDMilan
    Boca Raton, FL
  15. ferrallas
    Civic Si(1999 Spec)
    Int-265 dur. / 10.5mm lift
    Exh-267 dur. / 9.6mm lift
    Integra GS-R
    Int-274 dur. / 10.7mm lift
    Exh-276 dur. / 9.6mm lift
    Its a good upgrade the GSR cams?
  16. JDM-Ownz
    JDM-Ownz New Member
    Anybody Knows the XS POWER Cams??
    Specs are:
    Intake : 0.461 , 293
    Exhaust : 0.468 , 295
    I need information or experiences with these cams.
    Thanks.
    Alex
