Originally posted by rschoener@May 5 2004, 03:43 PM
The difference is the number of notches on the shaft for the TDC sensor to read. The amount of notches also has to do with the Camgears. They are different for Vtec and Non-Vtec So basically you need to match the Cam Gear and Distributors together. Same i belive goes for all the SIngle cam setups. All for OBD1 & OBD2 Except OBD2 has a different connector on it that can be changed to use on OBD1 and vise a versa.
