B Series Into Crx
Discussion in 'HYBRID -> EG-EK / DC' started by mwasnp, Feb 11, 2003.
  1. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    I understand that motor mounts are necessary for this swap. Do I have to get aftermarket ones though or can I get some from an integra and if so what years? I am looking to see if I can save a little cash now, I will put better mounts in later when I swap in the built block, I am just putting in this ls motor because my dx motor is on its last legs (190k and burning like a qt of oil every 600 miles). Thanks
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    You will need third party motor mounts, and shift linkage, such as HASport, HCP, or Place Racing. HCP motor mounts will probably be the cheapest, i have a buddy who swears by them. You will need to do an MPFI swap, on your motor too because it is a DX. There are many good write ups on the CX to MPFI swap. Here are some good wiring sources:
    http://hybrid2.honda-perf.org/tech/4gdxtozc.html
    http://crxpower.com/phpBB2/viewtopic.php?t...86c50951d00874e
    Good Luck man...
  3. mwasnp
    Hopkins, MN
    Thanks for the info, much appreciated! :worthy:
