b series into hatch ek
Discussion in 'HYBRID -> EG-EK / DC' started by 22crazy, Mar 13, 2004.
  1. 22crazy
    22crazy Senior Member
    hey, i was reading in the faq about putting a b series into a ek non-si (SiR) and u need two mount; rear tranny and drivers side...i just wanted to make sure...is the rear tranny, the cross member mount...the one that looks like a triangle? thanks.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Not the mount, the bracket that goes to the mount needs to be replaced. The D series one is too short and thin.
  3. 22crazy
    ya, thanks, i just got one today...also, i have a b20...on the drivers side mount, do i need change the mount and the bracket to a si (SiR). thanks. ill post pictures of my motor soon
  4. webink_EK9
    webink_EK9 Senior Member
    Just the bracket. Your d series mount should work.
  5. chicken
    chicken Senior Member
    Sacramento, California
    b series into 96-00 civic.. use all stock mounts and brackets EXCEPT u need.. 99-00 SI rear bracket(triangle).. and driver bracket that bolts to the block..
  6. xj0hnx
    C.C.TX.
    Depends on the one that is on the motor already.
  7. jwn7
    jwn7 Member
    university of pittsburgh, pa
    i've been curious about this myself.
    which numbers are they? 7 and ???
  8. chicken
    E-14-1............... well if the one on the motor is a 99-00 SI one you dont need to change it.. if the motor is a gsr b20, b16.. u need the 99-00 si one.. gsr ones wont fit.. :D
  9. jwn7
    jwn7 Member
    ok so we get #7 and that e-14-1 piece (i don't think it's numbered correctly :unsure:) from the 99-00 si, and also #1 and 10 from the motor we're swapping.
    EVERYTHING else on there can be reused from the civic correct? all 5 rubber parts, all bolts / studs / nuts / washers correct?
  10. xj0hnx
    C.C.TX.
    On the 5th gen Civic with a B series you have to replace parts 1 and 10 with the B series but use parts 8 and 9 from the Civic. Not sure if on the EKs the rubbers from the B series match or not.
  11. chicken
    parts 1 and 10 from Bseries..
    parts 7 and E-14-1 from 99-00 si
    parts 2, 3, 4, 6 from 96-00 civic SOHC
  12. highlife
    highlife Senior Member
    Hi, im about to do the same swap here
    m going to swap a 97 B18B1 into my 00 civic EX coupe
    can i use the 97 LS ecu OBDIIa or do i have to use the 99+ LS ecu OBDIIb?
    the harness is stock on my ecu, will my ECU plug fit a P75 ecu?
    i dont want to be a dick by taking this thread but i SEARCHED already and didnt find anything on ECU swap.
    thanks
