b-series swap help
96civhb
hi i am new to the forum, and i am preparing to start my first engine swap on my 96 civic hatchback. i would like to put a b18 or b20 into it. i need anyone to give me any information i will need(wireing, motor mounts, exhaust,transmission, ect...). i would also like people to post and problems they ran into durring their swap that i might run into also. i need as much information as possible before i begine my swap. i think my main problem will be the wiring, i need someone to explain to me what i am hookin up and what i need to buy. thanks
[post=556387]Quoted post[/post]​
All the information you need should be in the FAQs section at the top of the main page of the forums. Read that first. Read, read, read, and read some more. Then read the forum section for the generation of car that matches yours. Most if not all of your questions will be answered by those two sections. THEN ask about any specific things you might not have found the answer to. Good luck.
ok i did the swap in a 96 2 door we put a b18a in it
we used a dizzy off a 97 integra and a ecu out of the same
and we bought the swap mounts off hasport.com
