IL B-series swap/parts for sale !!!CHEAP!!!!
Discussion in 'Parts: For Sale/Trade/Wanted' started by SPEEDFREAK0920, Aug 26, 2010.
  1. SPEEDFREAK0920
    SPEEDFREAK0920 Senior Member
    chI-t0wn fo0
    I have some quality parts for sale. I was intending on building a "big power" honda but some things have come up and I must sell everything. This is tough for me to do but I need the money. Moving into a new home and I need the cash. Up for sale is a FULLY BUILT LS/VTEC set-up for boost/nitrous. This motor is built to handle 500whp. Built with only the best parts on the market. The motor is complete and sitting on an engine stand. This was going into my 1996 Civic EX. I have everything needed to swap this into any 96-00 honda civic. If you want to swap this into your EG/DC/DA/EF all you need to do is purchase the correct mounts for your chassis. This is a READY-TO-SWAP engine/trans combo!
    EVERYTHING IS BRAND NEW! 0 miles on everything except the transmission (TRANS IS MINT. VERY CLEAN!)
    - B18B (Fresh out of the machine shop. Was DECKED, HONED, HOT TANKED)
    The oil pan was also hot tanked. Everything is clean enough to eat off of.
    - LS crank (Fresh out of the machine shop. Was HOT TANKED, POLISHED, BALANCED)
    - CP 9.0:1 compression pistons (BRAND NEW w/ piston rings)
    - Eagle H-Beam rods (BRAND NEW)
    - B16 head (Fresh out of the machine shop. Was rebuilt with OEM parts. Have receipt for all work done)
    - LS transmission (has longer gears for good gas mileage. I went with this transmission for the higher final drive. It is very clean and in great condition)$400 if sold seperately
    - COMETIC head gasket
    - BLOX SANDWICH PLATE (for ls/vtec)
    The motor was assembled with ACL RACE BEARINGS and ARP STUDS/BOLTS (every bolt and bearing is ACL RACE and ARP)
    I also have some random parts available:
    -ENERGY SUSPENSION POLYURETHANE MOTOR MOUNT INSERTS (1992 - 2000 Honda Civic (non Si)
    1992 - 1997 Honda del Sol (including B16 model) $40
    -B16 EM1 REAR T. BRACKET (BRAND NEW. just purchased from Honda dealer. this is the only mount needed to swap a B-series into 96-00 Honda Civics)$55
    -TIAL 38MM W.G (BRAND NEW)$200
    -OEM HONDA CIVIC MUD FLAPS $60
    -BRAND NEW 99-00 SI tail lights (i did not like the amber rears so I purchased these instead)$70
    -OEM 96-00 headlights$80
    -96-00 black housing headlights (may need some cleaning)$20
    -Comp Clutch Stg. 4 clutch kit (BRAND NEW. will fit ANY B-series)$400
    -Autometer Boost Gauge(needs a light bulb)$30
    I may have a few more things I am missing that I will post later. I would like to get $2200 for the MOTOR/TRANS (as stated, the motor is complete and sitting on an engine stand) I would rather not part anything on the motor out. I just want to get rid of it as a complete swap. Or I will sell the complete long block for $2000 and the transmission for $400.
    I am not trying to make any money off of this. I just want to make my money back and/or lose a little. My loss is your gain....
    CONTACT INFO: (847)562-six two seven zero TEXT ONLY asilva0920@yahoo.com
    I will try and post pics later (no camera right now) or I can send pics to your email/cell phone
    :spin:
  2. SPEEDFREAK0920
    chI-t0wn fo0
    bump it up
    all you need is a turbo setup and you'll have one quick honda ;)
  3. spoon_fed_civic
    spoon_fed_civic New Member
    Missouri
    whats the price on the motor?
    i didnt see it anywhere in the post.
  4. darkstarrskata
    darkstarrskata New Member
    i just want atleast the b16 head
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    :ph34r:
  6. hollywood95240
    hollywood95240 New Member
    so you have everything to install this into my 98 civic
  7. hollywood95240
  8. spoon_fed_civic
    Missouri
