B-series Tranny Speed VS. MPH
Discussion in 'Reference Materials' started by pissedoffsol, Jan 6, 2004.
  1. pissedoffsol
    This information is intended to help everyone running a b-series transmission. The charts below list the top speed in each gear factoring in final drive and tire diameter. Obviously, there are other tire/wheel sizes here that I haven't listed however the sizes listed give you an idea when considering the small changes in overall diameter between slightly bigger wheel/tire combinations. If you need a specific application, email me (chet@hondaswap.com) and I can give you more exact numbers.
    The below speeds/rpm drop down points assume an engine with an 8000 rpm redline.
    <table style="width: 100%">
    <tr><th colspan="3">94-01 GSR Transmission (S80)</th></tr>
    <tr><td colspan="3">15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    Tire Diameter = 23.1 Inches
    4.4 Final Drive
    </td></tr>
    <tr><td>Gear</td><td>Shift RPM</td><td>Speed @ 8000 RPM (mph)</td></tr>
    <tr><td>1st</td><td>N/A </td><td>38.7</td></tr>
    <tr><td>2nd</td><td>4706</td><td>65.8</td></tr>
    <tr><td>3rd</td><td>5726</td><td>91.9</td></tr>
    <tr><td>4th</td><td>6082</td><td>120.8</td></tr>
    <tr><td>5th</td><td>6089</td><td>158.8</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3527</td></tr>
    </table>
    <table style="width: 100%;">
    15' 195-50-15 Tires
    14' 185-60-14 Tires
    Tire Diameter = 22.7 Inches
    4.4 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>38.0</td></tr>
    <tr><td>2nd</td><td>4706</td><td>64.6</td></tr>
    <tr><td>3rd</td><td>5726</td><td>90.3</td></tr>
    <tr><td>4th</td><td>6082</td><td>118.7</td></tr>
    <tr><td>5th</td><td>6089</td><td>156.0</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3589</td></tr>
    </table>
    <tr><th colspan="3">92-93 GSR Transmission</th></tr>
    15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    4.4 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>37.8</td></tr>
    <tr><td>2nd</td><td>5092</td><td>59.4</td></tr>
    <tr><td>3rd</td><td>5545</td><td>85.6</td></tr>
    <tr><td>4th</td><td>6070</td><td>112.9</td></tr>
    <tr><td>5th</td><td>6323</td><td>142.8</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3922</td></tr>
    </table>
    15' 195-50-15 Tires
    14' 185-60-14 Tires
    4.4 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>37.3</td></tr>
    <tr><td>2nd</td><td>5092</td><td>58.6</td></tr>
    <tr><td>3rd</td><td>5545</td><td>84.5</td></tr>
    <tr><td>4th</td><td>6070</td><td>111.4</td></tr>
    <tr><td>5th</td><td>6323</td><td>140.9</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3973</td></tr>
    </table>
    <tr><th colspan="3">94-01 LS Transmission</th></tr>
    15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    4.266 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>39.9</td></tr>
    <tr><td>2nd</td><td>4706</td><td>67.8</td></tr>
    <tr><td>3rd</td><td>5343</td><td>101.6</td></tr>
    <tr><td>4th</td><td>6090</td><td>133.4</td></tr>
    <tr><td>5th</td><td>5913</td><td>180.5</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3103</td></tr>
    </table>
    15' 195-50-15 Tires
    14' 185-60-14 Tires
    4.266 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>39.2</td></tr>
    <tr><td>2nd</td><td>4706</td><td>66.7</td></tr>
    <tr><td>3rd</td><td>5343</td><td>99.8</td></tr>
    <tr><td>4th</td><td>6090</td><td>131.1</td></tr>
    <tr><td>5th</td><td>5913</td><td>177.4</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3157</td></tr>
    </table>
    <tr><th colspan="3">B16A (92 ), USDM ITR, CTR Transmission</th></tr>
    15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    4.4 Final Drive
    </td></tr>
    <tr><td>2nd</td><td>5214</td><td>59.4</td></tr>
    <tr><td>3rd</td><td>5541</td><td>85.7</td></tr>
    <tr><td>4th</td><td>6074</td><td>112.9</td></tr>
    <tr><td>5th</td><td>5128</td><td>147.3</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3801</td></tr>
    </table>
    15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    4.4 Final Drive
    </td></tr>
    </table>
    15' 195-50-15 Tires
    14' 185-60-14 Tires
    4.4 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>38.2</td></tr>
    <tr><td>2nd</td><td>5214</td><td>58.6</td></tr>
    <tr><td>3rd</td><td>5541</td><td>84.6</td></tr>
    <tr><td>4th</td><td>6074</td><td>111.4</td></tr>
    <tr><td>5th</td><td>5128</td><td>145.4</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3851</td></tr>
    </table>
    <tr><th colspan="3">90-93 LS Transmission</th></tr>
    15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    4.266 Final Drive
    </td></tr>
    <tr><td>5th</td><td>6145</td><td>173.7</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3224</td></tr>
    </table>
    15' 195-50-15 Tires
    14' 185-60-14 Tires
    4.266 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>39.4</td></tr>
    <tr><td>2nd</td><td>4706</td><td>66.9</td></tr>
    <tr><td>3rd</td><td>5343</td><td>100.2</td></tr>
    <tr><td>4th</td><td>6090</td><td>131.7</td></tr>
    <tr><td>5th</td><td>6145</td><td>171.4</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3267</td></tr>
    </table>
    <tr><th colspan="3">JDM S1, J1, Y1 Transmission</th></tr>
    15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    4.4 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>38.4</td></tr>
    <tr><td>2nd</td><td>5051</td><td>60.9</td></tr>
    <tr><td>3rd</td><td>5520</td><td>88.2</td></tr>
    <tr><td>4th</td><td>6232</td><td>113.3</td></tr>
    <tr><td>5th</td><td>6571</td><td>137.9</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>4061</td></tr>
    </table>
    <tr><td colspan="3"><p class="regtext">
    15' 195-50-15 Tires
    14' 185-60-14 Tires
    4.4 Final Drive
    </td></tr>
    <tr><td>1st</td><td>N/A </td><td>37.9</td></tr>
    <tr><td>2nd</td><td>5051</td><td>60.1</td></tr>
    <tr><td>3rd</td><td>5520</td><td>87.1</td></tr>
    <tr><td>4th</td><td>6232</td><td>111.8</td></tr>
    <tr><td>5th</td><td>6571</td><td>136.1</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>4114</td></tr>
    </table>
    <tr><th colspan="3">European Integra Type R Transmission (98 )</th></tr>
    15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    4.785 Final Drive
    </td></tr>
    <tr><td>5th</td><td>6128</td><td>147.3</td></tr>
    </table>
    <tr><th colspan="3">JDM Integra Type R Transmission (98 )</th></tr>
    15' 205-50-15 Tires
    14' 195-60-14 Tires
    13' 185-70-13 Tires
    4.785 Final Drive
    </td></tr>
    <tr><td>4th</td><td>6082</td><td>111.1</td></tr>
    <tr><td>5th</td><td>6089</td><td>146.0</td></tr>
    <tr><td colspan="2">RPM in top gear at 70mph:</td><td>3836</td></tr>
    </table>
