Are all the B-series trannies interchangable? I am putting a B18 into my Civic and I was curious to see if any of the others will interchange, such as the YS1 to the Y80 or YS1 to the S80.
what year civic do you have? if its 88-91 you have to convert the engine to obd-0, which you swap out injectors, distributer, alternator, maybe 02 sensor(not too sure because some obd-1 ran 4 wire o2's, and obd-0 are 1 wire)
and then u can get the hasport mount kit for ur car so u dont have to swap the transmission. You need this kit, so u dont have to swap trannys
