b swap questions
Discussion in 'General Tech and Maintenance' started by Beatzzz92214, Feb 1, 2012.
  1. Beatzzz92214
    Beatzzz92214 New Member
    I have a b18 swap infront of me da9 and a ef wagon... i was wondering if anyone would know what i would do about the wiring harness
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Add all the connections that are missing?
  3. Beatzzz92214
    all the connections are missing?
    no I was wondering if i had to swap the entire harness? dash and all..or jus the motor mount harness?
  4. phunky.buddha
    Usually neither- just add the wires you need to run the B18. If it's a non-VTEC non-OBD engine, you really just have to wire it up for 2 more injectors and a different distributor. Look up DPFI to MPFI conversion.
