B16 200hp?
Discussion in 'General Tech and Maintenance' started by Justin66, Aug 31, 2008.
  1. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Ok to end a little bet i have with a friend who claims a 1.6 cant get 200+ crank HP without either turbo or stage 3 cams. I know i need to dyno and im not claiming anything yet so dont get me wrong. Skunk2 claims with a "custom header", sk2 exhaust, short ram and stage 1 cams you can get 190 HP from the stock 160-165.
    My setup will be (next year when i have bought everything):
    JDM B16a SiR2
    -chipped P30
    -custom header with 2.5" pipe and HKS muffler
    -short ram intake (going cold air soon)
    -adj FPR
    -sk2 intake manifold
    -stage 1 sk2 cams with adj cam gears
    With a mild tune.
    Do you think its possible to achieve 200 crank hp or more with this setup. I know that the tune matters alot and such but as a rough estimate? i will obviously have to find out next year but you guys im sure have seen many setups and figures. To be honest my goal is 200+ crank HP, and ill be happy. Any input would be appriciated, just dont flame, this is only an estimate. Just wanna know what im getting into. If anyone sees a problem or a better way or anything else id need (fuel or TB or whatever) to get this power?
    Thanks.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    im gonna guess around 150-170 tops. it takes alot to get a all motor b16 to the 200hp mark and it takes even more to get the torque over 130. but this is whp and torque im talking
  3. 99turbosi
    99turbosi New Member
    Mo
    Sounds about like what I have (every bolt on) except I have hondata. But I did'nt have my cams in. Mine dynoed 155 whp.
  4. Justin66
    I dont want whp figures tho, and damn that was quick.
    Also adding 8.8 or 10mm spark wires to the setup ( i know it wont do much but every little bit helps).
  5. AHHVTEC
    Alabama
    at the crank i think you will be close
  6. Justin66
    I have read (on here) that a 200 WHP N/A B16A is hard without stage 3 cams, headwork, compression and mass bolt ons and tuning. Its not the WHP im after althought it would be nice, 200+ crank is good enough for me..... and my budget.
  7. AHHVTEC
    Alabama
    i think with a intake manifold and maybe a new throttle body you will be there just get a good tune
  8. Justin66
    K that makes sence, i just added on to the SK2 figure they gave. An intake mani could add 5-12 from what ive heard (depending on setup) on a high output 4cyl, im thinking that a b16a is a "high output" 4cyl, since its higher hp than any 1.6 non turbo ive seen.
  9. phunky.buddha
    Dallas / Fort Worth, TX
    200hp @ crank = about 170whp. That's easy all motor on a B16- just don't expect to get there without changing out your pistons or going with really aggressive cams and a really aggressive tune. Most B16s dyno about 140whp stock, so you're trying to gain 30whp without going inside. Good luck.
  10. BoostedHatch
    BoostedHatch get tha fuck out!
    Bossier City, Louisiana
    :werd:
  11. SONIC SHREK
    SONIC SHREK New Member
    I built a b16. 13.1 compression, eagle rods, buddy club springs, blox retainers, supertech valves and some custom crower cams. A RAGE header and type r intake manifold and throttle body. I dyno'd 197 hp at the wheels on race gas! So good luck!
  12. Justin66
    Well if a B18C5 can make almost 200hp, whats so different from what ill be adding, minus the compression i suppose.
  13. tartymctang2357
    tartymctang2357 Grand High Wizard
    philadelphia
    a port and polish and a bigger stroke
    1 person likes this.
  14. Justin66
    Damn my short stroke and damn my lack of funds.
