okay guys need help on wiring and some info b4 i do this.......first of all the car is a 95 dx and the engine is a jdm b16a obd1 from a 92 eg 4door chassy. the car is auto and the swap is auto as well and it comes with p30 ecu.
now we are having difficulties with the wiring. since its jdm wiring i have to
replace with a usdm harness.......the plan was to use the dx harness and plug in
the vtec wires seperately. so now we tried to match up the wires to see if it
works, but the dx harness has a couple of plugs extra, which is the map sensor
and another plug that goes to the side of the intake manifold.so, would the dx
harness work with the b16a swap??? and if so, where is the map sensor on my
b16a, and does dx have knock sensor plug?
