hey
sorry about the poly mount thread, didnt know where to post it, but thanx for the link!
ok im swapping in a 2000 b16 a2 into a 93 del sol. i used my d series harness and changed the alternator, dizzy and injectors to obd 1, so everything plugs in, i got the whole motor mounted and everything plugged in, so i go to start the thing a few days ago when i was last workin on it, got everything plugged in except the fuel rail )needed to get the nut) so i disconnected the fuel and just wanted to see if it would crank, it clicked a bunch of times, im like ok just a low battery. so i get the new nut for fuel, try today and it clicked once and then nothing, it wont crank, it wont click agian eithe, so i grabbed my d series starter and just hooked up the wires and grounded it to the frame (didnt bolt it into the tranny) try to see if its the starter in the b16, well same thing, one click and then a little puff of smoke. any idea's, i checked my grounds, all hooked up all connectors are plugged in on shock towers. it almost sounds like a short with a puff of smoke, but im not sure what to think of this. never seen this and like i said, its the same harness so what the heck?...
also if anyone has a pic or something of the how the fuse layout is under the dash of a del sol or civic, please post it, i dont have anything on my fuse cover under the dash and there is nothing in the manual...
thanx again
del slo...
if this is in the wrong forum just move it, there are so many forums i dont know how to pick which one.
thanx again
del slo...
