b16 and b18 specs?
Discussion in 'Engine Building' started by lude68, Nov 6, 2003.
  1. lude68
    lude68 Senior Member
    j/w what the different specs are on a b16 and b18 (as far as bore, rod length, etc.). Someone told me if i put a b16 crank in a b18 w/ b18 rods and pistons it would stroke it to a 1.9L. is this true or is he full of shit?
    thanx for the info.
  2. E_SolSi
    for specs go to the reference section ... its all in there
    for the B16 stroking a B18 to a 1.9 i think hes full of shit
  3. phunky.buddha
    Dallas / Fort Worth, TX
    He's full of shit. If you put a B16 crank into a B18 block you'll have B16 displacement in a B18 block regardless of what rod length you use.
    B16
    Bore = 81mm
    Stroke = 77mm
    Rod = 134.6mm
    B18
    Bore = 81mm
    Stroke = 89mm
    Rod= 137mm
    I'm just recalling the rod lengths off the top of my head, but I'm pretty sure they're right. You might try consulting our reference section too.
  4. lude68
    k thanx a lot! i didnt even think about checking the reference sec. for some reason.
  5. B16
    B16 Super Moderator VIP
    yay area, CA
    stroke is soley based on the crankshaft
    and displacement is boreXstroke
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    yeah, full of hovno (czech for crap) and check out the reference section like the boys said..
  7. phunky.buddha
    Whoops, I was wrong- the rod length on the B16 is 134.36 not 134.6. Not that much different, but my rod/stroke ratio check calculation was coming out wrong.
  8. brian11to1
    brian11to1 Senior Member
    If you put a b20B crank in a B18 it increases to 2.0 or somewhere close is what I was told, is that correct?
  9. GSRCRXsi
    MD
    no, the cranks are the same. b20 has a 84mm bore, thats why it has 2.0l
  10. minnisvtec
    minnisvtec this is why i am hot
    I happen to disagree becaust the bore is the same on b 16 b18 and b18 but they all have diff displacements. the stroke and rod size and dech height do increase the stroke has to do with it just like if you just add a bigger crank to a 302 you get a 310. but now a b17 rods wont fit in a b18 block! because of the shortness of them so you have to try it an see
  11. minnisvtec
    i actually tried to put b 17 rods in a b18 block for less compresson and the crank actually hit the pistons
  12. minnisvtec
    lol now i see where you comin from i am on your band wagon
  13. phunky.buddha
  14. phunky.buddha
  15. B16
    yay area, CA
    They all have different displacements because they have different cranks which changes the stroke. Where are you disagreeing with me, I can't make sense out of your statement.
  16. klyph
    klyph Dismember VIP
    North Pole, AK
    Wow
    usually I'm like "he posted that 3 years ago, it's pointless to bring this back up"
    but there you are with a rebuttal.
    Amazing.
  17. B16
    yay area, CA
    Its not pointless if there is value add to the topic at hand. Lets wait and see. :)
  18. phunky.buddha
  19. stmotorsports
    stmotorsports Senior Member
    Buffalo, NY
    actually I would be interested in hearing more about minnisvtec trying to put B17 slugs in a B18, I was looking to try this
