b16 automatic
Discussion in 'HYBRID -> EG-EK / DC' started by sbcsam, Oct 29, 2003.
  1. sbcsam
    sbcsam Junior Member
    hey guys do you all know by any chance if there is a b16a II automatic, cause it just ordered my engine and i think i got an ecu from an automatic.
  2. sbcsam
    i've read that it is recomended to change out the water pump before i install the engine, but what water pump will fit my b16
  3. Jesus Christ
    Jesus Christ Guest
    The automatic ECU should work for the engine. I dont know how good it will work but it should be able to run the engine. OBD1 is the easiest because you can choose from many different ecu's but OBD2 has more restrictions.
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Yes there was a B16 that had an auto tranny in Japan. You don't want to use that ECU.
    Get a water pump for a Del Sol VTEC or a 99-00 Civic Si.
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    yeah what he said...
