b16 build up
Discussion in 'Engine Building' started by Kolumbo69, Mar 15, 2004.
  1. Kolumbo69
    Kolumbo69 Senior Member
    Calgary canada
    This weekend i got an offer i couldnt refuse 1500 for a b16a1 full swap except for axles. So my question is how much of a hp increase will i see if i put in itr(2000) cams with ctr pistons? With this setup what parts do you think should be changed and will i have to run a different ecu then the one i have?
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    the question is,,,,,,what car is this going into.
  3. Kolumbo69
    Calgary canada
    Its going into my 90 crx si
  4. AlphaCivic
    AlphaCivic Member
    San Diego
    hp increase really depends on what other mods you have and the condition of your motor.
    reccomend with those pistons you get total seal rings : just good safety because of the higher compression. you would benefit from doing springs and retainers to be able to safely rev higher to extract maximum power from those cams, and in that case a programmed ecu would be good to change your redline and get some better fuel maps (or by what ever other means) but you would be fine with no head work and your swap ecu. :D
