Yes I'm doing an LS/Vtec right now. They can make lots of power and will have more torque than anything well besides a b20 crvtec. It would probably be the cheapest for you as well. Also if I were you I'd get some b16 pistons while your at it and raise your compression. I'm using PR3 USDM B16 pistons with a gsr head and its going to have 12.2:1 compression. With that, a good set of cams, intake mani, header, exhaust, port and polish, 255lph pump, and a good tune you should be able to make your 200whp goal.
