B16 Cam upgrades
Discussion in 'Engine Building' started by 91_stylin_civic, Jun 27, 2010.
  1. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    So I am taking the head off my B16 in my 91 Hatch and would like to upgrade the valvetrain when it is off. I have never upgraded the valvetrain on any of my hondas so I am looking for an suggestions for a nice all motor setup(Cams,Springs,Retainers,Cam gears). The car does not get driven everyday but not trying to go too aggressive with it. Any suggestions would be great. I just dont wanna throw parts at it and not have good results.
    Thanks
  2. Treezy
    Treezy Evasive Illusions
    Currently in Iraq
    If you look at performance gains per cost, skunk2 has a good line-up at a good price. For more gains (if your lead foot gets itchy), would suggest taking a look at toda for N/A. Supertech and crower also make good head components if you want more, but skunk2 is a very commonly used and worthwhile upgrade.
    1 person likes this.
  3. Magana559
    Magana559 The Warden
    fresno Ca
    SIvalves.com for springs and retainers(make sure you know how big cams your gonna run, and what tension you need). Valves will work on N/A applications and on mild boost setups.
    Firerra valves on High HP engines.
    your choice of cams Crower, skunk, blox, BC, Toda, Ect Ect.
  4. hatchbuild10
    hatchbuild10 New Member
    Cali
    You could always go for the cheap mans way and ctr cams. They are a great upgrade and not very aggresive. This will also raise your vtec ingagement and it is a little bit louder. Have fun!!
  5. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    ^^^^ Not that cheap. You'd be lucky to find CTR cams used for less then $400
  6. hatchbuild10
    Cali
    Sorry I forgot I got m cams while i was in japan. they are pretty common over here. You are right they are rare but fun item.
  7. Magana559
    fresno Ca
    Yeah ctr cams arent cheap. you can get a set of used crower cams cheaper with larger gains.
    Raise your vtec engagement? how is it going to raise it by just swapping the cams? you need to change that by tuning or hack. the cams dont dictate what rpm vtec enguages. thats all done by tuning.
    stop posting false info.
  8. 91_stylin_civic
    New Jersey
