b16 cams
Discussion in 'Engine Building' started by 2000sivtec, Oct 19, 2009.
  1. 2000sivtec
    2000sivtec New Member
    I have b16 what cams would I have to get. So that its sounds like its cammed
  2. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    Skunk2 Pro 3s should do it. Just know you're going to need a whole new valvetrain with the kind of lift and duration you want. And not like its just a good idea to get it, you WILL NEED it.
  3. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    I think it still idles normally with the stage 3 cams someone correct me if i am wrong
  4. efhondakid
    Akron-Canton, Ohio
    Toda VTEACKH killers will make it sound like it has some cams in it.
  5. double0Si
    Columbus, Ohio
    Yea just saw that. I thought it was just 1 and 2. Guess you gotta go custom. Overlap doesn't make power in an engine that makes most its power on compression and high revving. So not many companies care to make a cam for it.
  6. eg6sir
    simple ITR cams will do the trick..
