I saw in a magazine that theres a turbo kit for a crx with a b16 swap, I cant find the magazine. Does anyone know what turbo kit that is and who makes it?
http://www.revhard.com/turbokit/efcivictur...c&engine=hybrid http://www.dragturbokits.com/ there's more, and you can pretty much get any b-series turbo kit, throw out the junk FMU that it comes with and run uberdata, and adjust the IC piping to fit. thats really the only differences...
I was just wondering about clearance issues between the motor and radiator to fit a turbo without modification
as long as the turbo is small enough, and the manifold isn't crazy, it will fit. you can always move to an EG 1/2 sized civic radiator too...
I had to install a 92-95 civic radiator in my CRX to get my turbo to clear. My setup is a home made short tubular manifold, T3 .48/.60, FMIC 25x5x2.5, DSM 450cc, walboro 255lph, 62mm tb, 2" pipe from turbo to IC, 2.5" pipe from IC to intake, 2.5" dp, 3" exhaust to a resonator and magnaflow muffler, tuned with turbo edit. I will get a pic of the radiator installed in just a minute for you. Oh yea, I also dont have ANY AC in my car. No condensor and no pipes or any AC compnents. I took out my washer fluid resivoir so I could make a cold air intake for my turbo.... EDIT:I had to modify the lower radiator support to get this to fit and cut some of the hood subframe out to clear the rad cap and mount, but its not hard at all. Just takes a lil time. PS: PLEASE ignore the "Type R" valve cover. I have plans to grind that shit off and repaint the thing.
