b16 distributor plug
when doing the dual point to multi piont injection harness how do u chang the distbutor plug wire from the dx harness and where the the other wires in the plug go to
do search on dualpoint to multipoint there are two wires that you need to run from ecu pins b10 and b12 these wires are you crank angle position sensor wires there will be a blue/yellow and a blue/green im not sure which wires go to which pins thats why you need to do a search
