B16 Driveshafts length?
Jayamashey
Finally got my car runing but once I took it out and hit 20 KM an hour it shook live mad (more straight than turning - its seems to ease on the turns). There is something the matter with the driveshafts but I need to figure out what.
When I installed them I could only tighten them so the nut was flush with the end of the shaft (unlike my D16 which had a 1/4 inch of the shaft outside the outer part of the nut). I bought them from an EF that already had them installed (with a B16 1st gen (possibly with ABS) - at least I am sure they had them installed).
I am not sure if they are warped or if they are too long. I had a heck of a time getting the driver side ball joint back in. Over a year ago I installed JDM from knuckles from a civic (ie. bigger front brakes) so this may affect it.
What length should the shafts be? Or should I look for some type of seal to remove? If the shafts are ABS would they cause it to 'bumb' like crazy when driving straight?
I am running a 2nd gen b16 with a JDM S1 tranny(tranny is good - drove it before it was installed in my car). Car is an '89 Si without ABS.
Any thoughts would be appreciated.
have the dust rings been removed from the CV joint and knuckle/hub?
I bought a set of Non ABS drive shafts and put the ball joint end from the '89 onto the end. This worked perfectly and got rid of the bumpy binding.
