b16 ECU voltage question
Discussion in 'ECU's, Electronics, and Tuning' started by autox19, Sep 23, 2014.
  1. autox19
    autox19 Member
    Lansnig, Michigan
    trying to troubleshoot a no start situation. I have a rywire race harness (open ends, not plugged into car wiring because the car isnt a honda) I am starting to run down the harness thinking I dont have the leads connected to the right places. Already used what rywire sent and it still wont work. EC was kept indoors the past 2 years during the engine swap. donor car ran fine before the engine/ecu was ripped out.
    So, to the question. I see that there are diagrams with the pinouts with voltages associated with them. but what I am trying to figure out is which pins have power going in. Key off, key on, key start.
    thanks!
    Odie
    Fiat X1/9 B16
  2. autox19
    autox19 Member
    Lansnig, Michigan
    finally found this link!
    http://rusefi.com/wiki/index.php?title=Vehicle:Honda_Accord_1995
    it has exactly what I wanted. unlike some of the pinouts that shows voltage and what it goes to, this one actually has a column for if the voltage is either in or out!! with this, I probably could have built my own harness. oh well the rywire is nice. hoping to start up the fiat/b16 tomorrow
    Odie
    Briansol likes this.
  3. Briansol
    Thanks for sharing.
    Sorry no one was able to help you on this one
