b16 engine mounts
h22bubbleback
will 2nd gen mounts off a b16 work on 1st gen b16 when droppin it in an EG?
meaning, some have an offset pattern and some have a straight pattern (where the bracket bolts to the mount), so you need to make sure that they will bolt to your mounts. I believe that the later ones ie: 94+ have the straight pattern, and the -95 civics have the offset. Mine are 93 and offset.
