I have an ef with a b16 obd0 swap and i have done the same thing with the code still there. I have no idea y and I'm having trouble finding anyone who has also had this problem.
Make sure you have the right connector hooked up to it. There are three plugs in that area that can be plugged into the wrong things. Check the wire colors against what should be there.
