no i have posted a few other places and have bben told it could not be a code 43 on my crx..
"43 is an obd-1 and obd-2 code so i'm pretty sure it's not that. maybe your not counting right. the 3 short could be for the MAP Sensor. the long blinks could be for a code 10 which is Air Intake Sensor. you could also be throwing a (from you what you said) a 13 which is the Baro Sensor...there's only one reason you'd throw this code with a B16, if i remember correctly but i don't remember exactly why. someone else can probably help you on that one. hope this helps"
Did you have to switch any wire on your harness for that swap? I'm thinking that you have not have one or two wires properly hooked up on the intake manifold. I had similar problems doing my first zc swap. After getting those hooked up it was good ta go. I'll do some checking if I get a chance between changing diapers. Now you see why I can't do many swaps anymore?! haha
