B16 Head On Gsr Block?
jdmspec5
Hey,
How would a GSR motor with a b16 head work, and what parts would i need for this? Have B16 and looking into options.
it will mount right up as far as i know
it will lower your CR slightly though
Yeah, but only lowers .2 I believe. This setup is pretty good for turbo.
yes it roughly lowers it by .2, there are many variables that affect the actual correct number and CC's. You want TQ, then go with more liters of displacement. And, yes, the head works B series parts are interchangable, hence B series.
Milan
B has a 16 head on a 18c1, it's a pretty good setup for boost if you bore it to 84mm and have it resleeved (which will also bring your CR back up the .2 it loses from the b16 head), it's what I want to eventually have
