B16 Head With Gsr Block
Discussion in 'Engine Building' started by mical0259, Jan 5, 2003.
  1. mical0259
    mical0259 Junior Member
    i got a 2000 si head and a GSR complete bottom end. i know they will just mate right together but i was concerned about power ratings and compression. i heard this will drastically lower the compression but then i heard it will raise it because it changes the deck height. has anyone ever done this and do you have any input you could give me. if you have, any idea what kind of power it puts down compared to a regular B16 and a regular GSR?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Compression will drop by .2 nothing crazy. You will have more power than the B16 and less than the GSR. You can regain that power by running Type R pistons.
  3. canon
    canon Junior Member
    B) A crack on my air intake on my b18c with no replacement. Ihad a b16a head fitted,and alsofitted b16 pistons (pr3).
    The result felt better especially top speed,but remember the second stage flaps in the b18c was not working infact was removed
    Now thinking of fitting b18c cams on b16a head that is on b18c block
    wonder how that will be!!!
