B16 help
Discussion in 'Engine Building' started by mano, Mar 14, 2008.
  1. mano
    mano Junior Member
    i have b16a4 engine can i put GSR pistons in it,if ok i want to know how much the compression.
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    It is possible, but why would you want to? =/
  3. a_white51
    a_white51 New Member
    Elma, WA
    this is acutally my next project and i'm using left over parts from my last project. Never gone boosted before so I'm not expecting any big numbers or anything but a gsr head and pistons with a b16 block I should be yielding a 9.1-9.4:1 cr. should be good to hold 10 lbs. pretty easy
  4. a_white51
    Elma, WA
    I really don't have any set goals. since I have all the parts laying around, it isn't costing me anything. I plan to use a dsm turbo set up so that won't cost much. besides that the only other thing I need is an extra tranny, being the only tranny I have is in my car now. So I guess my only real goal is to continue learning through repitition. No racecar for me this summer so building a boosted b16 is my new plan.
  5. a_white51
    Elma, WA
    mind pointing me in the right direction then? I thought I had a pretty solid plan and was only looking at spending $800-$1000 to get it together and running
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Pretty much just google people running similar setups :) This usually leads to new information and such.
  7. a_white51
    Elma, WA
    i have friends running similar setups and have researched on the internet
  8. a_white51
    Elma, WA
    did i ever say that? no. just stating i have friends with similar set-ups. If i claimed to know everything then i wouldn't be doing this project as a learning experience like previously stated.
  9. LS_VTEC
    NJ
    Scott is being a meanie today. :)
  10. EvoTec1
    EvoTec1 Member
    Tacoma, WA
    freakin genius... I never thought of googling setups in such a manner. <---TARD
