DAMCOOLDAV
Member
Hey guys i finally got my b16 today, was shipped to my mechanics garage, so i went over and took a look. Everything looks awesome, i'm very impresses and arrived on time.....i got it from HMO. Anyway my mechanic only really works on american cars, and hasn't delt with vtec before. So he is totally lost on that aspect and i have to do it. I know i have to take off the jdm wiring harness and use mine from my 91 integra. I also know i have to cut off the connectors for the vtec wires. However i'm a little shady on the vtec stuff myself. How many plugs are there for the vtec?? I know there are 4 wires i have to put into the ecu, but how many connectors are there? also where are they?? i know i saw a couple extra connectors right next to the dist., but i just wanted to make sure those were it. And one of the connectors was pulled out and the wire cut off, what do i do?? I guess my biggest question is how do i find out which connectors and wires are the ones that i need or are the vtec i should say? i need the vtec solenoid, pressure switch, knock sensor, and o2 sensor.......are they all in the same place? And also, all those wires need to go into one of the connectors on the 91 teg harness to go into the ecu correcT? thanks guys.....
