Originally posted by Samuels@Mar 2 2005, 06:38 PM
I did'nt no changing cam seals involve a timing light??
I thought I just had to take the valve cover off pop the end caps off the cams and put the new 1's on.
[post=468462]Quoted post[/post]
I dont know about the LS motor, but with a B16 its just those cam caps and teh seal is right under those. EASY as shit. that was the first "below the valve cover" repair I have ever done.
EDIT: I have never used a timing light to set my timgin EVER. I just set the cam and crank timing then, adjust the dist as I see fit. usually just put it back in teh original location. I have played with it a couple time and felt a lack of power or maybe a slight increase, but I was worried about pre-ignition so back to stock location for me
