B16 in eg, ecu problem???
Discussion in 'HYBRID -> EG-EK / DC' started by 93cxhatch, Aug 13, 2005.
  1. 93cxhatch
    93cxhatch Senior Member
    Seattle, Washington
    Alright I have been working on this problem for way too long...
    I have a custom programmed and chipped p28 ecu with a obd0 b16 in my eg hatch
    The motor keeps fluctuating between 900 and 1200 rpms when I start it, then when I hit the gas it is bubbly and sometimes dies if not when I hit the gas then when I take my foot of the gas. The ecu keeps throwing code 14 for the IACV I have replaced the Iacv 3 times and redone the the wiring all along it once. Could there be something else throwing off the code??? Perhaps timing, my dizzy or my ecu is bad??? Any Ideas???
  2. 98civic4door
    98civic4door Junior Member
    Sounds like a bad ecu or that your tps needs to be looked at.
